Velociraptor Front Wheel "Floating" Spacer?
Old-Raptor-guy
USA
Wilwood's version. I believe they do it so they can make one rotor, and then different hats with different lug holes and "off set/back spacing" for different vehicles (to line rotor up with center line of caliper)
downforce137
In Diana
aftermarket floating brake rotor...def not a wheel spacer
after looking again, there might be small spacer in front unless that is part of the rotor, probably wheel to caliper clearance issue...
i dont see anything strange out back
CleverGirl_
Cabin Clown
I still see a aftermarket fancy ass rotor, and a small removable spacer, but I have been wrong once.
xsandman
Hennessey installed cheap spacers on my 2018 on front tires only due to the large Brembo brakes they added... i think they do this so they can use the same method wheels on all trucks no matter if brembo is added or not.
