Uneven Exhaust tips....easy Fix!
Big Blue
Administrator
Staff member
Admin
USA
Hi all,
I noticed my exhaust tips were not even/level with each other a few months back. I offroad my beast and it's no show truck, but it started to nag on me. I have seen other posts here saying the same, one side is higher/lower than the other.
So today I jumped under the truck and 5 minutes later....Fixed. Super easy solution. The rear bracket is adjustable. Simply loosen both 10MM nuts with deep socket (Pics 1). No need for wrench on other side (see pic 2) of bracket. Lift or lower exhaust to desired position with one hand and tighten bracket nuts with the other. Done. (Pic 3)
James L
Manitoba
You know I saw that right away! Then I looked at others and they seemed all like that with one side higher.
I appreciate this and I will be crawling under tomorrow!
