GEN 2 Tailpipe issue
RaptorWings
Jacksonville, Fl.
2017 Ford F-150 Raptor
107k miles
So the height is the same on both tail pipes but for some reason the right side seems to be angled upwards. No matter how much I readjust it (about 10 times already) it still does this. My dad thinks its a defect on the tailpipe itself (these are the stock ones) (Only have a AWE h-pipe) so I wanted to see if anyone else has noticed this problem or if its just me. Anything would help. Thanks in advance.
Nex
RIP CoronaRaptor
Washington State
The ones near are not good and have horrible reviews
Then go to a different one.
If it bothers you so much to make a thread about it, you will need to sorce a solution near you. If you have already adjusted 10 times as you stated, then you either need to buy a new exhaust or go to an exhaust shop and have them put heat in them to adjust to your liking. Is this your first truck?
I think your dad is trolling you.
Go to an exhaust shop.
Fùck that, beat that M.F. with a rubber mallet until it’s back in line.
Fire. Is. COOL.
Ok, so hit that M.F. with some fire AND a big âss rubber mallet.
Repeat as needed.
if you don’t like the outcome, this is why God created the Sawzall.
