- Joined
- Dec 16, 2016
- Posts
- 16,568
- Reaction score
- 24,560
some good work there. I didn’t realize the truck was primer on the INSIDE as well as outside! :-O
like i said earlier before everyone told you to upgrade the entire system...... a set of speakers will give you a bit more clarity, but not volume. so if thats all you want, a cheap set of speakers will work. while most people do the entire upgrade, its dependent on what the person wants. if only doing speakers, theres no reason to spend a whole lot because you wont get the full potential of what the speaker can do, so keep it cheap. sound treatment in the door is up to you, but just remember, if you decide to do more, you will need to replace the speakers once again.Looks like I'll leave it stock then, because like I said in the original post, I do not want to do a full system upgrade.
I just don't care enough about it to sink money into it. If I'm going to blow that kind of cash, I'll just put it in the long travel fund. lol I'll enjoy that way more.
Agree , I bought those block off plates and sis the inner door skins . Wish I did back of the plastic door panel .The biggest and only real improvement for the $$$ that you can do without a full upgrade is to install the block-off plates in the doors. These will improve your mid-bass, reduce road noise, and will not break the bank. As others said, speakers will be minimal by themselves. Here is a link to those plates and you can read through the 35 reviews to get an idea.
Custom Made Door Access Block Off Plates - Compatible with SuperCrew (SCREW) 2015-2020 Ford F-150 + 2017-2022 Super Duty
Are you looking to build the ultimate enclosure in your door panel? If so, these block-off access plates will improve your mid-bass performance and deliver the sound you're looking for.- Hand-made here at our facility just outside of Nashville, TN- Available for the front doors & rear doors- Use...soundsgoodstereo.com
