SDI E CLICK preview gen 3 (live valve tune)
Sitdown
Suburbia, IL
Thanks for the info and testing, any further feedback @SMIKE ? Are you running their tophat, or has any of your testing been done with collars or springs?
Long shot, but curious if there is ability to save your custom settings (or preloaded SDI map), so after restarting truck you wont need to re-adj each time? Just know a G1 user running live valves and the kit noted that as one downside, but hoped that changed with our platform or newer kits
HOLLYWOOD 1
2Sun AZ
I'm running the SDI EClik on my 20 Gen 2. Settings stay where they are. Only time they change is when you manually make a change.
RBA
California
What is going on with this? It's been a while. When will it finally be available? Is the installation the same as on the Gen 2? I had it on my '20 Raptor and really liked the improvement except for the occasional issues of the unit not powering up. Each time I was told that it was a loose connection. Which did seem to fix it but annoying.
I'm curious whether the difference in performance be as noticeable on my '22.
