RPG UCA w/ NON-ICON UCA 1" RETROFIT DELTA JOINT
Yukon Joe
Trafford, PA
My RPG UCAs (1" Raceline UCAs) need new bearing. Unfortunately, RPG doesn't offer a seal bearing version for the fabricated UCA.
I'm considering using the Icon 1" retrofit delta joint. It is a sealed uniball with a grease fitting. The spherical bearings just don't last very long in the muck and grime that Night Raptor sees. Anyone with experience making this change? @bigred1097
NON-ICON UCA 1" RETROFIT DELTA JOINT​
Thanks,
@Yukon Joe
Rick at FMS
aka:Rick @ FreedomMotorsports
SW Virginia / SW Missouri
@Yukon Joe
Wow a ghost on FRF. Hello Joe!
Are you in Arkansas now and not the east coast?
As far as the Delta Joints, the RPG uniballs you have now are they any of these?
WSSX16, AWX16, WC16, WE16, WSSB16, WR16, ABW16
2012SCSVT
CA
Hello I recently did this.
The delta joints give slightly more misalignment than the uniball/misalignment spacers that come with the rpg's. Also the delta joints end up moving the pivot up so the uca can droop out further than the rpg set up, of course it's still limited by the spring contact.
2012SCSVT
CA
See attached
Yukon Joe
Yukon Joe
Trafford, PA
@Yukon Joe
I've bounced around.
Currently I'm in Pittsburgh, PA.
I ended up going with the Delta joint. Needed something sealed to keep out the winter salt and slush.
