Rough Country Fog Lights wiring
Bignose13
Utah
Can anyone give me pointers on connecting the wires that come with the lights to the upfitter switches.
Seems like of bunch of extra stuff..
Kirby Lastinger
Lakeland, FL
All you need is the black and power wire directly from the lights. You don’t need the relay, fuse, or switch. All that is addressed with upfitter switches. Power red to one upfitter wire. Black wire to ground on fire wall and you should be good to go.
NathanRoss93
Colorado Springs
Hey guys I have a quick question. I bought the Rough Country fog lights second hand off a dude. He combined all the black wires into one and all the blue wires into one, and finally all the white's into one. What would you guys connect to the factory wires? Blues to the green/white? Then the the white to the brown/blue?
This probably deserves its own thread. Need more information here. What model lights are they, what is the current draw of them per light and how many are you combining together?
Which up fitter are you connecting to? You may need a relay depending on which one selected.
Generally, the black wire needs a good chassis ground, and red to switched power, aka the up fitter. But, if your proposed current draw is 80% or more of the rating of the up fitter, a relay should be used and a home run to the battery done. There are numerous examples on here.
