Rigid fog light backlit
Enersol
Houston
I have my lights hooked up and wired to the lightswitches, so I found the bundle of wire. But I cant find the pass through wires for the backlights to connect. I saw all the videos and both bundles should by next to each other but I cant find them. Am I missing something or are the dead wires located somewhere else?
Enersol
Enersol
Houston
Also, I have the kick panel removed on the passengerside and the dead wires are the same as the colors for the switches. Am I wrong that there should be two different sets of wire bundles?
James O
Lubbock Texas 79407
Did you not find the second wire bundle under the hood? Its below the power supply set and they are just a pass through wire set.
Enersol
Enersol
Houston
I just ended up running them to my aux 5 switch. Bummer cuz now I only have one switch left for the grill light bar.
