Parking lights will no longer work
St. Louis
Hi guys, I installed Morimoto grill lights in January, and this week they stopped working - in fact all 9 parking lights in front stopped working. A previous owner wired them to upfitter switch #3, so I tried that and one Morimoto was out and my right side corner marker was out. I plugged in my OEM grill light, installed a new corner marker bulb, and checked fuse #30. However, they still don’t light up unless I flip the switch on. This was never the case. I’ve owned the truck for 10 months and the marker lights always worked the same as every other Raptor (turn on when remote start is used etc.), but now they only come on when the switch is on.
I really don’t think this has to do with the aftermarket wiring as that still works just fine. Any ideas on what’s going on?
did you check for DTC’s? a module fault will in some cases kill a circuit before tripping a fuse.
RennsportRaptor
St. Louis
Yeah that’s kinda why I’m asking to be honest. I have no idea how to check for DTC’s. I heard turning the headlights on and off like 3 times will reset it, but that hasn’t worked for me.
Nex
RIP CoronaRaptor
Washington State
Use forescan and check for codes. Think Smurf is on the right track. Might be a control module issue now due to aftermarket lights.
FordTechOne
Detroit
If the aftermarket lights are tied into the factory lighting circuits you’re going to have continual issues. Sounds like you need to go through the wiring and find what was hacked up.
