GEN 2 Map and Cargo lights strobing/flickering with doors closed- AMP steps deploying at random
FordTechOne
Detroit
I didn't think about that before when I was running the self test but it makes sense now. Are you saying the AMP running boards could be causing the problem? When I left the dealership yesterday and they started acting up, I disconnected them from the OBD port but the problems with the lights and rear cargo window remained. Wouldn't that rule them out?
Once network communication is interrupted the issues can remain. Leave the aftermarket stuff disconnected and re-evaluate.
I’d go a step further - once the steps are removed, check FORSCAN again for any stored codes. They will survive a battery disconnect/reconnect. Once you’re sure steps are disconnected and there are no stored module codes, disconnect the battery for a few minutes, then reconnect.
I’ve only had one BCM fault and it survived power off / on and battery disconnect.
