JL VXi
flwrappeder
north florida
Holy chit. I finally finished installing all my audio equipment and speakers in my gen 3. I got some really good direct fitment parts from @SoundsGoodStereo. Their amp board and speaker mounts were perfect. I went with a JL VXi 600i 6 channel amp, the zen A2b, JL c3 6.5s in all 4 doors and the component highs in the pillars. I also lined the inside structure of the door and the exterior side behind the door panel with that foam chit. I cut my own “block off” plates with 1/4” HDPE paneling 299B07F9-469E-47AC-AAF8-EC2F2972FE47.jpegand screwed them in place covering the big holes behind the door panels. I ran 12 guage wire for all 4 door speakers and 16 guage to the highs. The doors were a b I t c h but got them ran. The sound, the sound is the best I’ve ever heard. I’ve put systems in all my previous vehicles but this is the first where I kept the factory head unit in place. The zen made that really easy. The VXi amp is unbelievable. Sitting in the front seat and tuning all the channels with my MacBook was really cool. To sit stationary in the drivers seat and dial them all in was worth the extra money for that amp. The tun software was a learning curve but not too difficult to navigate. The only thing i wish I would have done different is getting the 8 channel version of the VXI and doing a 3 way set up in the front. And I very may well do that. If so I’ll have a 6channel to part with on the cheap. I’m going to try a pair of C7s in the front doors as soon as they get back in stock somewhere and would like to put 2 C7 3.5s in the dash. But as it is with the C3s it’s a billion times better than the B&O. I still have a lot left to learn about the tun software, I wish the mobile app had more features to make eq adjustments from time to time, but I think the JL drc 205 knob can be programmed to change presets. I could be wrong about that. It’s wired in but having a hard time deciding where to mount it through the dash. Not a lot of real estate to have at an easy reach.
flwrappeder
flwrappeder
north florida
Here’s a pic of the amp and mounting board. Already ordered a MTI box and JL Tw3 12. Will clean this up a bit after installing the second amp. Had some trial and error with the zen
Hotrod-Realtor
Mooresville, NC
I'm enjoying your write up. I plan to pull the door panels off, install block off plates and add sound deadening. What is the foam chit you speak of?
SoundsGoodStereo
F-Series Stereo Specialist
Nashville, TN
Here is a walk-through video that might help.
Also, here are the parts you will need to make it happen:
Legacy32
Houston, Texas
MTI can send ou a file for your truck that will set up the EQ for your set up. I had a similar set up in my superduty, that they set up.
The Car Stereo Company
here, on frf
we never use the surround speakers. im pretty sure sage over at sounds good doesnt use them either. a 2 way or 3 way active in the front is all you really need. you want a front sound stage. you dont want to compare to a home theater surround setup as it is different than car audio.
W1N
Helsinki, Finland
I agree 100%, I was just wondering if I used for example ZEN-A2B, would that remove surrounds entirely? Where does ZEN connects to OEM system?
