Infinite Reality's LED Thread
Nick@Apollo-Optics
Falcon
Ozarks
For me, no load resistors for only replacing fronts. When I do the rears, I think I will need them OR if I'm lucky since mine is 2010 I maybe can just replace a flasher... it's a long shot though and probably still have to install them for brake lights to keep cruise control happy.
I have been chasing the 2010 Hyperflash for a while now. I have been told both that the 2010 Gen1 DOES have a flasher relay, and that it DOES NOT have a relay... instead using the SJB (which I don't even know if the 2010 HAS one or not). I am still trying to figure it out. Did you FIND the Flasher relay on your Truck? If so, WHERE? Thanks!
CleverGirl_
Cabin Clown
Since I found some mixed information while trying to research what LEDs I wanted and need on my Raptor without having to go through a vendor and pay 10x as much, I thought it best to start my own thread to showing what is need, links to where I got mine, prices, pictures and even some video.
INTERIOR
For the map lights by the rear view mirror it takes TWO 194 bulbs, the one I got has 6 Samsung LEDs on it.
http://www.ebay.com/itm/23088515002...d=link&campid=5338805043&toolid=20001&mkevt=1
For the dome lights, I used one 42mm festoon type 6-SMD Samsung LED bulbs. SCrew trucks have 3 bulbs.
4 42mm 16 SMD LED White Car Dome Festoon Interior Light Bulb | eBay
For the vanity mirror lights I used #74 bulbs with 4 SMD LEDs, my truck took 2 total, only 1 light per mirror.
http://www.ebay.com/itm/11096818788...d=link&campid=5338805043&toolid=20001&mkevt=1
EXTERIOR (FRONT)
Front signals are 3157 bulbs, I bought a pair of 54-SMD LED amber bulbs. By doing this, I had no flasher issues on my truck.
2X Amber 3156 3157 SMD 54 LED Corner Signal Brake Blinker Light Bulbs | eBay
Front side markers are 194 size bulbs, I bought a pair of 5-SMD LED amber bulbs.
2pcs 168 194 T10 5 SMD Amber Orange LED Parking Light Bulbs Interior USA SHIP | eBay
Puddle lights, I used 31mm festoon you have to cut the lense off them and once that is done you can replace the bulbs, all plug & play. Just make sure to seal it up good, I used some 5min epoxy to seal mine up.
2X White Dome 16 LED 3528 SMD Festoon Interior Bulb Light 31mm DC 12V New | eBay
EXTERIOR (REAR)
Cargo and reverse lights I used 921/194 bulbs, bought a pair of 25W LED white bulbs.
http://www.ebay.com/itm/37116020793...d=link&campid=5338805043&toolid=20001&mkevt=1
License plate lights, used a pair of 194 Samsung LED bulbs that I used for my map lights above.
I installed four 68-SMD LED red bulbs, just installed and not sure on signal action as of yet... WILL UPDATE
GP Thunder Pair 3157 3057 4157 SMD 68 LED Lights Bulbs Red | eBay
Quick run down of bulb pictures for when the eBay links go bad in a few months. They're in order as I listed above
INTERIOR
EXTERIOR (FRONT)
EXTERIOR (REAR)
[/IMG]
Now for installed pictures, again in order as I listed them above
INTERIOR
2010 Raptor Interior LED Lights - YouTube
EXTERIOR (FRONT)
2010 Raptor LED Retrofit Puddle Lights - YouTube
EXTERIOR (REAR)
Stock bulbs left, LED right.
Inside Shot Of LEDs
Both sides installed
@V1ROTATE add to cart lol
