Horrible design flaw
whtrapta
Ostrich Wrangler
Bolivar/Springfield, MO
I found out today, over night we had some light rain and turned into snow. Well, in front of the windshield is that black grate that runs the width. That filled with ice and snow over night, no big deal right? Wrong. Thats where the intake for the cabin vent system is. So I was driving and couldn't figure out why my window defroster wouldn't keep the fog off the windscreen. Turns out, it couldn't pull any air in. And you cant have the air on recirculate and defrost at the same time. I had to go back home and poor water all across that grate to melt it so my vents could allow air in. How did Ford not suspect that something as simple as rain and snow could block the air vents? I have never had an issue with this on any other vehicle.
Hockster
My 45ft Bluewater Party
Winchester, Va
I wouldnt call it a design flaw... Where would you draw fresh air in from?
BIRDMAN
Birdministrator
Boston
i don't think unless it's totally plugged it would make much of a difference? mine was packed with a couple inches of snow today and my defroster was crankin...did yours really stop blowing significantly?
whtrapta
whtrapta
Ostrich Wrangler
ya, when i switched to the regular vents that blow from dash by the stereo and stuff, it was like being on speed 1, but the fan you could hear was maxed out. I was not happy.
SilverBolt
Hired Gun
Portland, OR & Eureka, MT
It has always been an issue with trucks. Snow is typically not a big deal but a bunch of ice will seal it tight. If you park outside you should throw a cover over the vents.
iceman302
Full Throttle OG
El Dorado Hills, CA
Hmmmm. That's rarely a problem out here in CA but I wonder if you could install a low voltage, moderate temperature heating element of some sort. I guess it could even be controlled by an aux switch.
JP7
Likes Canadian Mudbaths
Calgary, Alberta
Hmm - mines packed with ice (and has pretty much been that way since October) and I've never had a problem with heat, flow, defrost or fan speed. I leave it on auto all the time and never use recirc (I smoke). On days when I park at night while its snowing, I switch to defrost cuz the auto start remembers the setting and my windsheild is clear after 15-20 minutes of warming up.
I'd suggest getting it looked at next time you're in for service.
JP7
Calgary, Alberta
Oh hell - my old Bronco's did it. But none of the 98 - 2010 Fords I've owned have ever had that problem.
