help with rear bumper wiring harness
erniecsays
Los Angeles
hello all,
found this wire harness bouncing around in the rear… believe its for the rear bumper.
unsure if a result of the rear bumper being removed, or if it was never secured properly from factory (wouldn’t doubt it).
i see there are push pins to secure it in place, but for the life of me cannot find the holes to secure them to.
i know for sure the large connector should not be flopping around as is, makes me uncomfortable to say the least.
does anyone know how to properly route this? or if a fellow member could shoot a picture from under the truck it might give me a good idea.
much appreciated!
CleverGirl_
Cabin Clown
I would say that bumper has been off. You will want to tighten down that ground bolt for sure.
I don't have a Gen 3, so will let others help with the wires. Looks like it could be trailer or pro power related.
Paging @FordTechOne
Good catch
erniecsays
erniecsays
Los Angeles
Paging @FordTechOne
yeah, it was painted… my guess is thats where this mess came from.
i secured the harness best as possible with zip ties and the push pins i could find receiving holes for, I tightened the ground as well… its this guy thats concerning to me.
“If you want something done right, do it yourself” smh…
CleverGirl_
Cabin Clown
Is that connector plugged in to anything?
Antho
Absolutely need to tighten that ground on the frame. Thats a problem..
Antho
They ran the harness on the wrong side of the frame. You will have to disconnect it and undo the ground. Then route it properly.
Antho
The connector goes above the spare on the little crossmember. But you will have to unplug and disconnect the ground to route it properly.
erniecsays
erniecsays
Los Angeles
much appreciated! figured I would drop the spare and take a look when I got home this confirms it.
thanks all for the help!
