GEN 2 HELP!!! Raptor only making 250+hp on dyno!
Lacajun25
Dallas, Texas
$210K USD?
I believe it. I’ve visited VN several times and in conversations, was told that VN has crazy import taxes on vehicles. Basically any imported car will cost you 2x what it will cost in the US. That was 10 yrs ago. So I can see a Raptor costing $210k USD.
Only the wealthy and connected can afford nice cars in VN.
OP, good luck figuring out what the problem is. I’m interested in finding out what’s causing your issue.
Any chance you have a smart key programmed with restrictions or “valet mode”?
Woolaroc
Oklahoma
Sorry to bring this back up, did you get any resolution to the issue? I have a feeling that I'm not pulling as much boost as I should. I guess I'll do the 0-60 pull and see what the time is. How are you all timing this, safely?
vanisvandal
vanisvandal
Vietnam
I believe that it is due to dyno setup of the shop. I worked with another garage with Mustang Dyno and it gave me a reasonable dyno numbers now. No problem with my car whatsoever
