Help me identify this noise please!
Gumby
Nashville
Sorry...... had to re read this entire thing..... so we are still chasing Noise???? What is with the wrench when you go hard on it? That shouldn't be a a thing. This sounds to me like they might not be related?
V1ROTATE
V1ROTATE
Tennessee
Yes still chasing noise! Heard almost solely when inside the cab with doors closed. When the hood is open the injectors tend to drown it out.
The wrench is a blinking wrench and (i assumed) a misfire. sometimes the wrench goes away after it settles.
It went to ford and they said I had “water in my coil”. They cleaned it out and called it good. It did not fix either problem.
The misfire is most noticeable when it’s cold outside. I’ll feel the miss when it’s about 45 OAT but it won’t throw the code. I’ll try to get the code tonight when I leave for work since it will be cold enough. I just got forscan and didn’t have the ability to pull the code last time.
Gumby
Nashville
@V1ROTATE
You have pulled the belt? To rule out bearings? (noise) The wrench is the closed Evap or clogged possibly? The miss??? Is there one or not that is the question.???? A 12 year old truck with 25 k hasn't been used much = sitting that can be as hard as miles sometimes. water in a coil??????? I would replace that one for sure, was it #1 if so I would suspect The #1#4#8 with some moisture problems? I know you are a few hours away but if you get up this way. I am willing to try to help you with what ever I can.
V1ROTATE
V1ROTATE
Tennessee
@V1ROTATE
Belt, idlers and tensioner have been replaced on your suggestion. No luck. The EVAP is certainly ticking. Hit it with the stethoscope and it’s certainly mimicking the noise I’m hearing. That being said, it may be a normal tick. I need another raptor to compare it to. However I don’t think my EVAP numbers from forscan are normal. So that may be the noise issue.
I would also have replaced all those suspect coils, but it’s frustrating because I paid for premiumcare and assumed since coils are covered, ford would accomplish that. #8 showed 10 misfires on a 15 minute drive today. So it appears 1,4,8 are the misfire suspects.
V1ROTATE
V1ROTATE
Tennessee
Results from this morning
V1ROTATE
V1ROTATE
Tennessee
Bringing the truck in tomorrow to give the dealer one last chance to make it right. In the meantime I have new Denso coils on order to complete my plug,wire, coil inventory. My garage is full of Raptor parts and I don’t mind. My wife has a differing opinion.
