GEN 2 Hellwig Pro Series Helper Springs Install
Waylon The Raptor
TN
Thanks, Dudebrodude. Unfortunately, the rubber bumper(?) has to come out. It interferes with the two leaf's that are added to the stack. The fastener is a 5mm hex (see pic). I almost stripped the hole with an Allen, so I backed off. I wanted to make sure there wasn't a technique, or magic postion (WD-40).
NateMob
SATX
I remember that allen bolt being insanely tight also, you wont be reusing it so you could always run a sawzall or grinder in there and cut the bolt. Or, take a grinder and cut off both sides just above the rubber sleeve.
Good luck!
