grinding noise near the engine compartment
Yukon Joe
Trafford, PA
Do you have the defroster in when it starts? Having it on causes the AC to kick on, putting more load on the belt. You could try it both ways to see if it makes a difference.
Yukon Joe
O
ozzie06
You can remove the belt and rotate the tensioner and idler pulleys by hand and feel if they're rough. Another thing to think about is I know on mine when it starts and first runs for a bit when its about 30* and colder, the power steering pump makes a low humming whine till it warms up.
Thanks for the input everyone! ya pirate air, it only happens up here in flag when it gets below 30 so I was thinking it was the power steering pump is their any way to fix that? or do I just have to deal with it....
pirate air
will plunder your booty
Mines done it since its first winter and 2.5 years later it still does it but zero issues otherwise. I've flushed it with a synthetic fluid and no difference. Its been solid off road, no growling when run hard in the heat like I've seen others do, so at this point I don't wanna mess with it. I'll deal with the cold whine.
jdowens1
Ford Senior Master Technician
Montana
My power steering makes same noise as pirates since it was new. For has always been great for power steering noises when it's a cold start up. I'm just to lazy to worry about it never had a problem in 15k
MotuMute
Dallas, TX
Oh I thought this was a "grinding" noise thread - which sounds more like a belt tensioner pulley. Now it's who wants cheese with their whine? Does it sound like the end of this video? We all decided that was the PS pump
F-150 Raptor jump - YouTube
PropDr
Eugene, Oregon
The noise at the end of the vid is that of aerated hydraulic fluid.
Similar noise could be present in a hydraulic system at low temperatures due to cavitation.
