GooseTuned Gen 3 - Baseline Dyno Runs vs Gen 2 Baseline!
maxr
MT USA
They likely loaded the dyno up, or ran in a taller gear.
I lower torque slightly as well, and keep it flatter. It’s safer in the long run
thanks for the clarification. I will contact you via your website
MORaptor1
SW Missouri
Suppose I did the injectors or fuel pump work so I can run e85 full time and I had to fill with 91 or 93 at some point…? Is it just a reflash to a different tune until e85 is available again?
GooseTuned
GooseTuned
New Mexico
The injectors are what you want for Gen 3. You can just reflash, yep! Super easy.
maxr
MT USA
Hi Winfield .. was watching your "2021 Gen 3 Raptor Stage 2 ..." video and at the end, you showed stats for Stage 1, 91Oct vs Stage 2, 91Oct. I guess somewhere buried in 92 pages of posts there might be the actual dyno charts comparing these two but wondering if you could post them (again)?
I know there is essentially no gain from the FMIC in terms of HP or torque so wondering if the HP or Torque curve changes much with the FMIC ...
thanks
GooseTuned
GooseTuned
New Mexico
thanks
Yeah man!!
Stock vs COBB 91 vs Stage 1 Goose 91
Stage 2 91
GooseTuned
GooseTuned
New Mexico
I've since found more power on Stage 2, with downpipes:
Boost was incorrect on the plot, it's only making 21psi.
GooseTuned
GooseTuned
New Mexico
530-535whp as seen here, stock downpipes:
Below is currently the highest HP Stock turbo Gen 3, on ethanol:
552whp
639wtq
It has SPD downpipes too, which add 20hp.
