Gen3 Losing Brakes
KentSD
www.BookBaja.com Baja yacht Support
San Diego
Im losing all braking power on the truck. Truck has 2000 miles on it.
Unfortunately im down in Mex right now with very limited options here.
I had to finish the last stretch for an hour with no Brakes.
Ive disconnected the Neg Battery Cable to reset the computer a few times. That has done the trick. But keeps coming back and have almost lost the truck a few times.
Brakes are gone again from 5 min to 20 min....
Anyone experience this and what did Ford tell you?
not seen that one before. good luck, hopefully not going to be a long downtime.
KentSD
KentSD
San Diego
ill check but you press the brakes and nothing happens. So its safe to say they dont work
OGRE
Mine had similar issue and was from a loose line on the distribution block leaking brake fluid.
