Gen1 front coil spring part number
stlpolo419
St. Louis
Hi guys, I have a 2012 supercrew cab raptor. I’m trying to find replacement coil springs for it. But there are two part numbers and I can’t find the difference between the two. I don’t know if one is for the supercrew and one is for the crew cab. The two numbers are. AL3Z-5310-A And BL3Z-5310-A. Any help is appreciated!
Nex
RIP CoronaRaptor
Washington State
Give your springs a check. Might still see a part number or tag on them.
Or you can order a set from Geiser.
pat247
Oklahoma
The VIN for for the vehicle helps the ford parts dept. find the right parts for the truck.
CleverGirl_
Cabin Clown
old PN for the 5.4 Model is the AL3Z. Bl3Z is the updated one.
Get giesers or eibachs anyways.
pat247
Oklahoma
In the early days of the Raptor ford indicated that the Scab and Screw had different spring rates. The parts dept. at my local ford store asks for my vin. number when I need parts as the part numbers change from time to time. An FYI the 5.4 and 6.2 weight is nearly the same.
TomDirt
Hesperia CA
I bet they asked what color the truck is too.
To be honest, the difference between your driving styles, suspension and tire choices, & the load you carry; is more important than whether it's a SCAB or SCREW.
pat247
Oklahoma
I'm not smart enough to figure out that stuff so I let the ford engineers tell me what I need.
