Gen 3 Builtright Molle Panel
DMays
Tennessee
Wanted to share that the builtright industries Molle panel works with the Recaro seats. I had asked builtright and they said they didn’t think it would but luckily it did. Figured someone may be curious as well.
DMays
DMays
Tennessee
Just hangs off the headrest post?
It has rigid mounts to the head rest posts and at the bottom from the seat frame. It doesn't make contact with the leather at all. Most options have straps and it sits against the seat. I didn't want anything to touch the leather itself. Really nice product for sure.
rlj676
Detroit
Thanks for confirming!
I figured it would as the seat structure has to be identical, but was not sure if the bottom attachments would have access to the structure through trim.
Not sure what to store on one but I want it nonetheless.
DMays
DMays
Tennessee
Builtright thought the bottom attachment points wouldn't line up. I had no clue but wanted to try and they line up perfect. You unzip the back of the seat, and the mounting points are on the bottom seat frame itself. Pretty easy install. I will suggest mounting things to the panel before the install because it's hard to get your hand behind it once its mounted.
CTK59
New Mexico, it ain't "new" & it ain't "mexico"
Was is an easy install? Watched a video and seemed somewhat of a pain to attach bottom attachments.
rlj676
Detroit
Makes sense. The seat structure is a critical safety item so the recaros are built on the same as normal seats. As long as the trim cover was able to give access it would work as you found.
Yeah I did not enjoy mounting shit on my bedside panels after installed lol.
DMays
DMays
Tennessee
It was very easy. The hardest part was unzipping the seatback. Once I had that done I had the bracket mounted in 5 minutes. Total once I got the attachements mounted to the panel to zipping the seat back together was around 25 minutes
MNLeadfoot
MN
I was on the fence about these because I wasn't sure long term if they rubbed against the leather but I think you just sold me on them!
DMays
DMays
Tennessee
I added 4 washers to each side to get it a bit further from the seat to be 100% sure but it didn't touch the leather without the washers either. I don't see it touching the seat over time.
