Gen 2 OEM Skid Plate Hardware
fordraptorfun
Los Angeles
Anyone have the OEM part numbers for the 4 skid plate bolts and clip nuts towards the front of the skid plate? These are the ones that you need a 13mm socket to remove.
Not to be confused with the two bolts/nuts towards the rear of the skid plate that need a 15mm socket to remove.
HB4 and HN2 in the exploded view below.
OEMPlus Raptor
OEM preferred....
Oxnard CA
T1mbo-Slice
Fort Worth, TX
Is there a nut on top of the long 15mm bolt that goes at the back of the skid plate? Mine was missing the bolt so I ordered one and it just spins there and I can’t see up top to tell.
