G3 Specific Geiser Springs?
rpsully
I am running them in rear, with stock springs in front with RPG collar. Stiffens it up a little in the rear but not too bad, and ride height is little higher than front end currently like the stock look
scottybs
WA
Do you put much in the back or tow at all? If so how much squat. Only towing I do is a fly fishing drift boat with camping gear/bikes in/on bed and an occasional utility trailer.
rpsully
I mounted a rack and RTT by ROAM, and usually carry lots of MTB stuff, or bunch of rifles and ammo, but nothing too heavy. Haven’t pulled horse trailer with it yet since springs, but before it was basically impossible secondary to squat.
They claim 1” sag with 700lbs I believe.
JayRods
Manteca Ca
Job done, and they are awesome !!!!
I had the 4 new Geiser springs installed yesterday.
I carry around about 740 lbs of tools, parts, roller tray, and Dimondback cover. She was squatting pretty good.
The new springs raised the front about 1⅛" and the rear up 2½". Now my truck is perfectly level with that weight in it. My AMP steps are sitting at 11" front and rear.
They also did the alignment so everything is perfect again.
It still rides amazing. As good or better then stock. I was really worried that I was going to loose that cushy ride that it has on the factory springs. I thinks it's actually better especially because of the extra weight I carry around.
Very happy
Here are the before and after pics
JayRods
Manteca Ca
I towed the boat yesterday. I measured it before and after hooking up. It dropped 2 inches. I slid the boat back on the trailer 4" and gained about a ½", that put it at 1.5" sag. Still towed the boat great, so I'll leave it like this for now. I could slide the boat back more but I don't want to go to far. The boat has a 100 gallon fuel tank in the rear of the middle pontoon, it was half full yesterday. So I think a full tank will definitely change that measurement.
scottybs
WA
Anyone have any pics unloaded with only rears installed? Any ride bias compared to the stock fronts? I would like to get a little rake back when I’m loaded.
JayRods
Manteca Ca
I just took out my Slide tray and all of my supplies. So the only weight still back there is the Dimondback cover.
Looks like it went up 1" at the rear AMP step and almost 1½" at the rear fender well.
First picture is loaded after the Geiser springs installed.
The rest are now unloaded
44" at the fender well.
The AMP steps are 11" in the front 12" at the rear.
munch520
Midwest
Anyone with F+R Geisers get lean to the driver's side? I'm 3/8-1/2" high on the passenger side. IDK if it's a settling thing or something else. Have a half tank of gas.
Front:
42 3/16” driver
42 9/16” passenger
Rear:
44 3/16” driver
44 11/16” passenger
