Fuel Covert Wheels
Tampa, Florida
I feel you there, I have a garage that I can close because it doesn’t fit all the way. I don’t really know of the top of my head how tall it is but I’m very close. I’ll look later tonight and let you know
PalmettoGen2
PalmettoGen2
Greenville, SC
Vegas_Sirk
Boise, ID
JetG
I know it would be close just how close is the question. I am thinking of running 17's and 37's, just need to clear the parking garage 6'9"
Tampa, Florida
Looks good man! Have you noticed any side effects of running that setup with the live valve shocks?
Not really, there is slight decrease on the mpg's but that was expected. The BFG's KO3 wore the lightest tire I could find on a 37" ... well or more like 36.6 ish, they are never their true size except a few companies that make true 37s. The RAS in the back brought the rear back to almost level. Right now the rear sits about 1/2 inch taller than the front, but I like a bit of rake. It also took away a lot of the sway and lean that the truck had, once I add the hellwig rear sway bar I'm sure it'll be much better.
Las Vegas
Good looking wheel. I think the zephyr fuel wheel have the same offset and those are the ones I have on a 17x9 with 37”. I do have a 2.25 leveling kit up front and a RAS set up in the back for now.
HEY BROTHER THIS WHEEL AND TIRE COMBO ARE FIRE!!! CAN YOU HELP MEE WITH THE OFFSET OF THE WHEELS? OR ACTUALLY THE WHOLE PACKAKGE? lol thanks in advance.
wazatataza
miami
I had a similar wheel. Most of their wheels of this size are specked at 34 lbs. I had the D785 in bronze. they looked great dirty and clean. I ran them on the OE BFGs with no issues, full droop and tuck. Ran them hard and I gave them to a friend afterwards. If you go to 37s and you do things your doing in your picture without proper modification, your going to have a bad time. Mine were 0 offset, so 1mm more of poke than yours.
wazatataza
miami
You should clear. My hospital parking is 6'8" and i have 3-4 inches to spare on a leveled set up while on 35s. 37s will really only give you an inch. gigity
