Forscan troubles...
DatGuy14
VA
I got through pretty much every change I wanted to do in Forscan except for one...
Every time I make this change, I get a notice that pre-collision braking is turned off. Is there a way to make this change and keep pre-collision braking assist on?
Thanks!
Antho
Why disable it? You can toggle the feature off in the touchscreen. If you want it disabled via forscan, I think that the error will go away after driving it for a little bit. The steering may need to refind center etc. Try driving it for a little after making the change.
DatGuy14
VA
I want to disable it because I find the feature to be annoying. I get why its helpful for some, but I don't like it, and the alert that it is turned off every time you drop the truck in reverse, is almost as annoying as the feature itself, at least to me.
Thanks for the suggestion. I'll try giving it a drive and see if that clears to error.
