Floor jack discussion
NickPic83
Rockland County NY
I used 4x4 scrap before on my last truck. It had a 7" lift. It just never left me with a good feeling. Especially as I lift the trick I can see the moisture squeezing out of the wood
Stang
Get the Harbor Freight 2 ton low profile and their 6 ton jack stands. The jack lifts 23-3/4" and the higher load stands are taller. You won't find a floor jack that lifts much higher. This is their best jack if you read the reviews. Has a t-handle, foot pump and quick release knob as well.
http://m.harborfreight.com/automoti...profile-floor-jack-with-rapid-pump-68050.html
Sent from my SCH-I545 using Tapatalk
A.I.I.Raciing
Dezert 8MYMNEY
Costa Mesa
I've got 2 Crapsman Jacks from Sears that I've been using for almost 10 years, on all my trucks I stack 3 2x4's on top every time I lift a truck and haven't .had a single scare of the truck coming down on me. If you X them you'll be just fine
For the individual who mentioned a bottle jack, spend a few dollars get rid of that thing
Rickoo
Massachusetts
I've tried that. 2x4s are iffy at best. I use a 5 ton and a 6 ton (front and rear to rotate tires) and put 2x8s under them. It's way safer.
I'm a little curious on your process for rotating tires. If you're not using the spare, you have to get two diagonal wheels off the ground at the same time correct?
How is that safely accomplished?
Hate letting other folks rotate my tires, but without a lift, I'm not sure how to safely do it. I'm considering picking up a cheap tire/wheel and using it so I don't have to get two wheels off the ground at the same time. Really don't want to mess with dropping the spare every time I want to rotate.
Stang
Just get it up on 4 jack stands. The Harbor Freight 6 ton are high enough.
Reptar
Jersey
I jack the rear from the pumpkin, then put a 6 ton jack stand under each side of the axle. Remove the rear tires. Take the jack and jack up 1 front corner by the A-arm (toss a 3 ton jack stand under the frame rail just as safety), then I put that front corner on the rear, and one of the rears on that front corner. Then do the other front the same way.
Just buy a couple jack stands rather than another entire giant wheel/tire combo that you have to store, and that is useless for anything else besides rotating tires on your raptor, and more work bolting/unbolting it just to rotate.
Ruger
Northern Nevada
I rotate only front to back and do not use the spare. I put the lumber UNDER the wheels of the jacks, and jack both front and rear on the same side of the truck at the same time. Once both tires are off the ground, I use heavy duty jack stands for safety - with half of a 6,000 pound truck off the ground, a jack failure would be catastrophic.
BTW, the owner's manual says to never jack at the differential. It's unsafe to do that. You need one tire on the ground with the parking brake locked even if you are using tire chocks (which I do).
