Differential fluid change - do I need friction modifier?
Ruger
Northern Nevada
This is what the owner's manual says about the front diff: 1.8L of Motorcraft SAE 80W-90
Premium Rear Axle Lubricant
and for the rear diff: 2.6L of Motorcraft SAE 75W-140
Rear Synthetic Axle
The Owners Manual Supplement for the 2011 Raptor says the above but adds the following:
Rear axle fluid friction modifier
4 oz. (118 ml)
Additive Friction Modifier
Ford PN: XL-3 EST-M2C118-A
It's on page 24 of the Supplement.
MCR, I think you probably need to come to an understanding of this QUICKLY.
Madcowranch
Madcowranch
Genetically Modified
OK
4 oz. (118 ml)
It's 6 degrees outside anyway. Won't be changing it today. Yeah it'd be nice to get a def answer on the friction modifier.
Ruger
Northern Nevada
^ Oh you big chicken! Put on your woolies and go freeze your ass! ;)
Yeah, just kidding. It would take forever for the pumkin to drain and to refill it at those temperatures.
MCR, if you have the factory cover on your differential, how do you figure to refill it? If I remember right, the factory cover has a drain but no filler.
Humvee21
4 oz. (118 ml)
You are absolutely correct. Here's the fineprint to the capacities page:
4* Service refill capacity is determined by filling the axle to 1/4-9/16 inch (6-14 mm) below the
bottom of the filler hole with the vehicle on a level surface.
Add 4 oz. (118 ml) of Additive Friction Modifier XL-3 or equivalent meeting Ford specification
EST-M2C118-A, for complete fill of 8.8 inch Traction-Lok axles.
5*Your vehicle’s rear axle is filled with a synthetic rear axle lubricant and is considered lubricated
for life. These lubricants do not need to be checked or changed unless a leak is suspected, service
is required or the axle assembly has been submerged in water. The axle lubricant should be
changed any time the rear axle has been submerged in water.
Madcowranch
Madcowranch
OK
Yeah I did some deep ass water crossings last fall so I might have some contamination. Just being on the safe side.
