Can’t figure it out
mtnghost
california
Have you tried a leak down test, also maybe some sort of carbon cleaning. Fist do the leak down and see how much leakage and where it’s going. It will be in one of three places. Exhaust you would hear the air escape the tailpipe. Intake, you would hear it in the intake plenum or tube going to the air filter. Or three in the crank case. For that one pull the engine oil dipstick and look carefully for smoke coming from the tube. This is usually an indication for a bad or gummed up ring. The others are more likely valves and I have seen camshafts in some engines crack and have the same effect. Hope this at least gives you some direction in where to go next. Lastly have a block test done to check for a blown head gasket. Good luck.
