GEN 2 Camera issue in 2017 Raptor
KDAWG97M3
Hey guys I have an issue with my 2017 camera front and back. I used forscan to re calibrate, it has gotten worse since the sync upgrade (still sync 3) and funny thing is ford website says I have an update ready but the truck won’t take it. Not sure if my APIM is going bad? Any help or guidance would be appreciated.
FordTechOne
Detroit
Are you doing the 360 camera alignment procedure? It requires special mats placed in very specific positions to successfully calibrate the system.
KDAWG97M3
KDAWG97M3
Are you doing the 360 camera alignment procedure? It requires special mats placed in very specific positions to successfully calibrate the system. I just hit calibrate on forscan. The camera was doing this prior to me cal
It was
doing this prior to me “calibrating” the system. Maybe I made it worse. What is my call to action here? Dealer? Or a way to fix it? I was
going to try and upgrade sync one more
time to see if that fixed anything.
FordTechOne
Detroit
It was
It looks like the camera may be bad, but it really should be diagnosed to verify it’s not a circuit issue. It’s not likely the APIM, as the zoom and check surroundings message are clearly displayed on the screen. You can try to update Sync, but the software updates typically resolve intermittent issues, not a hard fault with the camera image.
KDAWG97M3
KDAWG97M3
I updated sync successfully, camera worked for a bit, then failed again. not sure next steps...
KDAWG97M3
KDAWG97M3
I do. I will pull now...
code B1530 trailer aid camera angle detection
alignment or adjustment incorrect
also to note my TPMS Sensors are throwing a code. I disabled the feature. Outside of that no Other DTC’s
