Body Creaking Sounds
New recaros
Colorado
I have this same issue (1,800 miles) on my 2023 gen3. There is a black rubber plug right where your hand is pushing down on the body. If you take off that black rubber plug, you will see where the two body panels meet. They are moving and rubbing against each other. Take your finger and place it on that area and step on the floor board. You should feel the "noise". I took some silicone spray and applied it to the area where they meet. The sound is gone!!!
I bet Oldfart has some really high quality silicone goat lube.
RaptorRudy
Phoenix, AZ
Mine does the same thing. I never noticed it but my friend with the same truck showed me this morning.
Now I can’t un hear it!!!!
Is he really a friend?
JDMCTR00
Los Angeles,CA
A real friend will tell you the truth even though it hurts to hear it. Try to spray it and let us know.
Chuckaroo91
Chuckaroo91
Boise, ID
It will come back. Can try silicone spray or graphite spray works, graphite spray seems to work longer.
BoostCreep
SoCal
I had the exact same issue as OP in the same spot. I also did what you did, but used white lithium grease. Made sure to get it between the two sheets of metal right where that plug goes in. Did this over two months ago and still silent.
