Anyone running 37x13.50x17?
Cody Templeton
Des Moines, IA
Thinking of going to a different wheel and tire setup for something a little more aggressive. Currently on 17x9 +12 Vision Ojos in bronze with 37x12.50 BFG T/A KO2. I like the setup and it's been pretty all around great, but I might be ready for a change. Thinking of going to the 37x13.50 Cooper STT Pro and the 17x9 -12 Fuel Militia in bronze.
HORN HIGH ACES
Colorado
I'm not sure how you use the truck, but that new set up will be problematic with light off-roading and may even have issues on road with stock fenders.
If you have aftermarket fenders and want a more aggressive look that's still pretty functional, I'd recommend 17x9 0 with 37x12.5 tires that are actually about 13" wide like the STT Pro's you are considering.
Nex
RIP CoronaRaptor
Washington State
Keep in mind, BFG 37s are smaller than most other 37s. I would keep with a zero offset. And start saving for fenders.
C
Cody Templeton
Des Moines, IA
I was kind of wondering about the 13.5 because I see almost nobody running that size. I just assumed it was because there's not much choice in tires in that size, but I'm assuming it's because they have bad rubbing issues. As far as the offset any specific reason to stick to a +0? Had no idea the STT Pro's were going to be that much bigger in the same "size" as the BFG's.
C
Cody Templeton
Des Moines, IA
I kind of wondered that too. I think I remember reading that somewhere else that even though they are are a 37x.12.50 they're actually a "small" 37x12.50. Any specific reason to stick with 0 offset? Also, is it mostly the front fenders you need the clearance for? I'm assuming you don't want to run just the bigger front fenders without doing the rears as well. Sucks because I believe the rears only come as full bedsides which is a lot of work.
Nex
RIP CoronaRaptor
Washington State
When I went from the BFG 37s on stock wheels to Baja Bosses on zero offset wheels. I could leave the parking lot without removing fender flares. Had to do the fender mod right away. Sure I am in a Gen 2 but you will still run into clearance issues. A negative offset will amplify the issue. You are already choosing a wider wheel over stock.
You can run just front fenders and be ok, most people do.
C
Cody Templeton
Des Moines, IA
I just thought it would look really weird with just the front fenders and not the bed sides to match.
HORN HIGH ACES
Colorado
The front flares are a bit smaller as these fenders are 2" higher and they will poke out about 2" further. Some people will color match the flares (front & rear) to minimize the difference, but I prefer the contrast so I went with satin black which matches my aftermarket bumpers.
C
Cody Templeton
Des Moines, IA
What fenders are those?
