Anyone drop the headliner yet?
trayack
trayack
Nantucket, MA
I got 75 squar feet to play with, so I plan on doing as much as possible within reason (pain in the ass). I don't want to pull the front seats, or the center console. I plan on doing the full roof, back wall, and both inner and outer skin of the doors. I will also try and get to as much of the floor as possible by lifting up the carpet, but like I said...I'm not going to totally strip it. I would like to get the roof and back wall done in one sitting.
I am hoping to get it done on thursday but there might be an issue with the stuff getting here by then.
The Car Stereo Company
aka grumpy car stereo guy
here, on frf
you will need more..... a lot more... trust me
trayack
trayack
Nantucket, MA
DONE. What a difference in noise level inside the cab. It's honestly like a different truck. I'll try and do a brief write up in the next few days for you guys.
wiz1500
Sorry I didn't see this so I could chime in, but Bussa had you covered anyway..
Glad you got it with no prob...
onesickpuppy
Ruler of the Earth
Does having/not having a moon roof make a differance as some of the real estate is not metal??? I would think the moon roof, with its mounts and braces, would have less kettle drum effect!!!!
Harblar
Aberdeen, SD
Good question! I'm planning to just do the doors and back wall for now. Was going to try to avoid having to pull the carpet and headliner out if I didn't have to. Got the moonroof as well and wasn't even sure how much could even be done without effecting its operation.
I'm going to start with some dynamat type stuff to start and eventually add foam and mass loaded vinyl.
trayack
trayack
Nantucket, MA
From what I found doing the roof and the back half doors made the most difference in overall noise. I wish I could cover up those stupid air passages in the back wall...The headliner was very easy to remove, in my SCab anyway.
wiz1500
Doing as much flexible metal as you can will always help..
The floor is really not needed...Ford has put heavy sound deadening material on it for us in key areas...If you do peal the carpet back you will see strings of epoxy that were laid down and allowed to harden..
trayack
trayack
Nantucket, MA
In my '13 there was very little factory deadener. No epoxi strips like in your picture and only a few 5x10 inch peices of factory deadener, mainly on the doors. If my memory serves me correct it was one strip on each major section of the door and a few here and there on the roof.
- Travis
Wrong Way
Im sure Dyna mat is not the only manufacture of this type of product, what are some other companies to check out? How about the weight, thickness etc.. Just looking for options if there is any?
