Anyone better options than OEM brake and rotor sets front and rear
Rick at FMS
aka:Rick @ FreedomMotorsports
SW Virginia / SW Missouri
shot..wrong forum....my bad...meant for Gen Too (the best gen)
You really should try our brake kit that has been on the forum here for 10 years. I replaced mine at 28k because I was headed to Baja and to be honest, I had plenty of rotor thickness and pad life but wanted to change them anyways. I had no real issue with braking but wanted an improvement. I know that I am trying to sell a product but to be completely honest, it made a very noticeable difference. We have had lots of customers just take off the OEM brakes and put ours on for just the performance improvement. You can use Promo Code FRFBRAKE15 if you are still needing to get yourself a set.
mtnghost
california
Um… this is a $1k front pad and rotor set. I’m pretty sure the op wanted replacement calipers and lines. Also drilled slotted in sand seems like a terrible idea. Just my 2c
Rick at FMS
The OP stated in his first post about rotors and pads. We have had thousands of raptor owners over the last 10 years use our kit off-road with aggressive driving with great results. We get positive feedback all the time. When I went to Baja, no issues whatsoever and this was my 6th time plus other off-road events.
Feel free to check our reviews in our section and vendor feedback.
mtnghost
california
Ok, I will check them out. I have some slotted drilled rotors up front atm, no complaints except stopping distance is a bit long. With the age of my truck now, I would be in the market to replace the calipers and lines with upgraded units at the same time I replace pads and rotors. Any recommendations on calipers and lines?
