500 miles, first impresions
warrior
Your Wife's Personal Trainer
first, love the truck and way different then my 07 Dodge, Raptor has gobs of power and drives small, handling is great and very little road noise tires and all. Screw has a large back seat, and my son digs the room. Ford did a nice job with the interior and so far all the gadgets work, rear camera is great as well as manuel shift.
Gas mileage is 11.7 so far and I expect that to get better (Dodge was 10 so I am ahead)
only concern so far is the rear clunking or axle wrap when starting from a stop?
need some driving lights (leave for work early)..........
and curious why Ford didnt use wheel liners in the back? would like to see that covered.
SPRSNK
I Void Warranties
Franklin, TN
My F350 does not have wheel well liners either. As to why, I would guess because the travel would rip them to shreds.
warrior
warrior
doubtful they would get torn off from travel? my Dodge didnt have them, BUT they where a option from the dealer. Great for keeping the dirt off the underside, I am considering having that LINEX'd? all the painted would be black Linex
BOJANGLES
<span style="color: red;"><b>Administrator</b></sp
Chihuahuan Desert (EPTX)
Actually one of my front fenderwell-plastic-liners is currently partially torn from bucking in some whoops and/or landing a jump. My General Grabbers are slightly larger than the stock BFG's, apparently the difference in size is enough to make it rub when fully compressed.
I tucked the plastic behind the fender as a temporary hold and I have a new liner on order
iceman302
Full Throttle OG
El Dorado Hills, CA
I think I'm going to do the same when I have the bed Line X'd. I don't like how the front fenderwell is all black but the rear is painted. It looks funny on anything other than a black truck.
Droid
kglesq's Brother
I went with truck bed paint on my '04 Sierra, fixed the problem, cost $10, and didn't chip over 2 years.
My only concern for Line-X in there would be dirt build up. As much as I otherwise love the stuff, Line-X's texture isn't the best in that regard. Already had to buy a wheel brush to clean the dirt buildup out of the running boards, and it seems its way too soft. Need to go by target and try a toilet/floor scrubbing brush...don't think I'm going to scratch them.
iceman302
Full Throttle OG
El Dorado Hills, CA
Maybe I'll go that route instead but I'm more worried about it getting chipped up and looking bad after awhile.
IRONMAN
Well-Known Member
MICHIGAN
I use a hard bristle srub brush and sometimes the stuff still doesn't want to come out. 3X4 brush with handle.
warrior
warrior
update, had the dealer check the rear clunk, lubed the rear pinion and presto NO clunk.
