2020 Rotor Retention Screw
JayDeFox
Grand Rapids,MI
Greetings,
I'm approaching the time to change Brakes and Rotors. I know from my previous Vehicles, Ford loves to use the retentions screws in their rotors. I've drilled this out before and this time around want to avoid that and come prepared. So my first question to the Raptor family is, does the 2020 Raptor have a set screw in the rotors? If so, what is the Torx size to remove these properly? What I've found is M8 X 20MM(TORX) but figured I would come here to confirm.
Thanks in advance,
Space Ghost
FL
pretty sure once you take off the caliper you can take the rotor off. Watched a vid on the front showing that, dont think the rear is any different other than putting it in brake service mode
JohnyPython
Canada
I didn’t think Ford used those. They just seat on the centre bore.
I use an impact driver on those. The one that you hit with a mallet. You wanna make sure you get a good bite on those.
