2012 Headlight bulbs?
STUTIDE
STUTIDE
South Carolina - Charlotte, NC area
Got a comparison pic?
Do a search on headlights bulbs. I forgot who did it but they did a VERY extensive comparison with before and after pix or search Phillips X-treme.
---------- Post added at 01:15 PM ---------- Previous post was at 01:13 PM ----------
Here ya go humvee
X-treme Power
---------- Post added at 01:15 PM ---------- Previous post was at 01:15 PM ----------
Cant get it to copy - just search phillips x-treme and you will see it
Humvee21
How do you remove stock bulb?
First you must remove headlight housing from front fascia. In order to do this you must unscrew 1 philips head screw (each headlight) that holds the rubber weather flaps in place. Then, remove 3 10mm bolts from each headlight (2 on top and 1 on side next to radiator and underneath rubber weather flap). Pull headlight away from front fascia in order to pop it off. Finally, unscrew the bulb from headlight housing by a simple 1/3 turn.
NickPic83
Rockland County NY
Stock headlights suck. Either do hid's in stock housings or do the best mod and do a retrofit with hid's. Check out ducati's thread
Sent from my DROID RAZR using Tapatalk 2
