2011 Raptor 300k issues
JA1972
California
Battery issues..thinking its the alternator..any info on how hard it is to change out ?? Already switched out battery...
The Car Stereo Company
here, on frf
a quick test is to start the truck and then disconnect the battery. if it still runs, then the alternator is good. also take a meter and check the voltage while its running. should be around the 14v range
Spectragod
Dayton Ohio
That’s a great technique, in 1970, if you want a burnt up pcm, go ahead and disconnect the battery with it running.
You replaced the battery, did you reset the BMS?
here, on frf
whether the key is on and the battery dies, or its running and the battery dies, its no different. i wouldnt suggest doing it everyday, but its a simple test to check that the alternator is functional or not. also, when you get your battery replaced, a lot of places will do it like this to retain all you memory features.
Spectragod
Dayton Ohio
Uhhh, yes it does matter. The pcm controls the alternator, there’s a reason the bms has to be reset after battery replacement, that diagnosis is not a good one.
Replacing the battery without resetting the bms will result in the alternator charging at its normal voltage but only at 10 amps, pretty soon, your battery will be dead, because the car is running off of it and your alternator is not charging the battery.
But feel free to diagnose as you choose, it’s that stuff that keeps me employed.
