- Joined
- Jul 15, 2017
- Posts
- 1,110
- Reaction score
- 1,008
Can anyone share details on the Rigid Radiance Scene lights? I absolutely love the amber backlighting but I fear the actual light output of the main LEDS is poorly focused. Is this a flood/scene style light? Or a driving/spot combo? Their advertisement is pretty vague.
I'm definitely upgrading these fogs. Does anyone have a good comparison or reason to select Rigid, Diode Dynamics, or Baja Designs? I really like the 2x 2x1 mini fog lamps for their looks, but am likely leaning towards 3x 2x2 style lights for the additional output.
Thanks!
Yes. We actually just did a video. Now before you watch this video, you REALLY need to understand that this is ONE single light. Not a pair. Not 3 pairs in which case you would have in the Raptor. That means in both cases with the standard Radiance or Scene, you would be 6X brighter than what you see in this video.
So this video isnt a comparison of how much light YOU will get. It is a comparison of the difference between the Radiance and Scene and the pattern throw.
The Scenes are 2970 lumens each. The 3000 lumen range is pretty standard with most offroad lights from Rigid, Baja Sports, Etc. Pretty standard Range. Though there may be differences in patterns.
The Standard Radiance are 900 lumens each. 1/3 that of the Scene. They are more of a budget point. But with 6 of them and 6,000 lumens (close to) They would be effectively similar output to ONE PAIR of Scenes. Make sense?
Here is the compare-
Now, this video is a bit older, but with a Raptor where we put 3 Radiance on one side and 3 Scenes on the other.
In my opinion, they Radiance and Scenes both provide a great coverage. It extends out wide and pretty far. I am not concerned with Spot, Flood, Driving Patterns as these cover just about all the areas you need and can truly be a headlight substitute and then some.
So if you like the effect of the amber backlight, they are a great choice. The standard Radiance are much more cost effective, and the Scenes offer the most light for those that want it.
John
