Skyfrog
Brandon, FL
A couple weeks ago I noticed the fans were running in turbo mode. Coolant level was low, so I added some with no change. Will help from some online searches, I isolated it to the A/C. Replaced the pressure sensor (one of the easiest things I’ve done on my Raptor). But that didn’t fix it either. Finally took it to a local mechanic to do an A/C service. Turned out to be a leaky Schrader valve on the high-pressure side. Also, had them do an oil change and the oil pan thread was stripped during my last oil change. They put in a “universal” plug for the time being. Any suggestions on replacing the oil pan or re-threading? I’ve been told its labor intensive to get the pan out.
