2010 raptor engine swap
OGMoltenSCAB
Northfeild VT.
I owned 2 f-350s with the 6.2 and currently own a 2010 SVT Raptor w/ 5.4, and it's a straight plug-and-play swap(You will need to have a Raptor ECU made by a shop for it. I was about to make the swap this past summer but my modded raptor with a 93 octane tune and 3d printed proper cold air intake and a larger throttle body is faster than most 4 door 6.2 raptors. Question is how much power do you want to make and gas mileage. 6.2 will make more HP reliably while 5.4 HO gets better mileage.
the 6.2 block is the same, but you need to change some parts over. i believe the crank shaft is one of them. oil pump too.
jdm_sixtwo
11MPG is average, right?
Beaufort, SC
Everything is shared except for the intake, and the cams. When you have the heads off to do cams, go ahead and port them and run ARP hardware. Just go ahead and future proof the truck. Rotating assembly is all the same. The super duty uses variable intake runners and the raptor doesn’t so a raptor intake is required, but as long as you have the intake off your old 6.2 just throw that on, as well as your old cams as long as the bearings are good
mtnghost
california
He has a 5.4L I’m pretty sure nothing is shared between that and the 6.2L. I’m new to fords so I could be totally wrong.
mtnghost
california
Oh damn, read the next post and got all mixed up. lol guess the op will have to clear that up. My bad.
