New Leveling Option - SDI Upper Mount
Springer01
I’ve seen a handful of people that experience this when running the Eibach springs on gen 2. I bet if you put stock springs back on it would go away.
That is my plan for over the weekend. I still have my original shocks with springs still on them. I sent ones I purchased used to SDI for revalving/rebuild.
erniecsays
Los Angeles
Anyone on here actually running the SDI upper mount?
going to be removing the front shocks to install an upper arm, i’m considering switching from rpg 1.5 perch to the SDI top hat since it’s being described as being more streetable with the preload being less.
chiming in to see if anyone has any real world experience with it.
So-Cal-Al-52
I Love Fossil Fuel
San Diego
I am also wondering the exact same thing, Running a 1.5 collar but considering the 1.7 top hat. I just can't seem to find much info or any pictures of how they sit. I know RPG has a new billet top hat but it has no lift just a reinforced top hat.
erniecsays
Los Angeles
yeah
yup, just trying to get some real world feedback.
in all my life its always been: do not stick a hockey puck on top of your shock!
but now a 1 inch spacer is OK? just a bit confused.
perch works fine for me, rides a bit rougher but if the SDI mount is best of both worlds then would like to hear about peoples experience.
BoostCreep
SoCal
yeah
The spacer part of the SDI is way less than half. I’m waiting on Foutz uca’s and then I will install the top hats and give some feedback. I had 1.5 RPG collars on my last truck.
hyrepower
Las Vegas, NV
If you are going to drop that kind of coin with upper arms and all, why not just do it right and get some Fox Race Series Coilovers. Not matter what, if you add preload to the OEM spring with OEM shocks, they will lose down travel and ride harsher, especially if you are offroading and need down travel.
I personally have been going back and forth with maybe getting a set of Icon Coilovers , rear bypasses and Live Valve delete. The only reason I am looking at the Icon as the King rear bypasses are so damn loud that they sound like you have a bunch of marbles in your bed when hitting bumps.
BoostCreep
SoCal
Because I’m also running E-Clik and it works better with the stock live valves than the Gen 2 FRS shocks. If and when Fox makes Gen 3 specific shocks, I’ll probably use those.
The preload from the top hat is pretty minimal, and it doesn’t move the static ride height out of the ride zone of the shock, so I don’t think it’s going to negatively impact ride, but we’ll see.
hyrepower
Las Vegas, NV
With e click you can adjust the rebound as well so you should be fine. I look forward to seeing and hearing how it turns out
Space Ghost
FL
Not to get too off-topic, but how so? Cause im getting the FRS live valves for my 20 and i have the eclik right now, SDI said it needed no change, unless this is G3 specific then ignore my peasant G2 whining.
