RST18: RPG RST18
RST18 with Recovery Rack: RST18 with Recovery Rack
Westside Offroad Group is proud to announce the Rear Shock Tower systems from RPG Offroad that pulls 18" of controlled wheel travel!
The bed cage uses your choice of either 16" Fox 3.0 piggyback bypass shocks, 16” Fox 3.5” piggyback bypass shocks and pulls 18" of controlled wheel travel when combined with custom built National Leaf Springs and our custom extended shackles. Through our extensive torture testing, we’ve found this setup extremely reliable, smooth, and effective at conquering the roughest terrain, the largest whoops, and the biggest jumps that the Raptor can handle. The increased droop travel provided by a bed cage system makes terrain that would have been spine shattering in even a Stage 4 Raptor, cushion soft.
RPG’s bed cage is the perfect solution for mounting your shocks and retaining as much usable bed space as possible. RPG Offroad engineering philosophy is to maximize both utility and performance, so the rack is low profile, both length and height wise, by design. Its low profile design ensures use of bed covers to protect your cargo. The design also minimizes the amount of cutting required to install the cage, minimizing the loss of usable bed cargo capacity.
Huge gains in shock travel lead to increased speed and control and we think that leads to increased fun in the desert playgrounds. Minimal impact on your usable bed space and utility matches the Raptor’s concept of a desert monster you can use daily. Built using laser cut sheet metal, CNC bent, seamless tubing, precision welding in-house at RPG HQ for optimum fit and strength, and powdercoated black for protection against the elements. The RPG bed cage is your next step in unleashing your Raptor’s desert conquering prowess.
This kit includes the rear shock tower; two weld on 4130 chromoly brackets for the lower shock mounts, and all necessary Grade 8 hardware.
For those of you interested in adding functionality to the RST18, there's also the RST18 with Recovery Rack. Designed as a full bed system that gives you all the proven performance gains from the standard setup, and also adds on mounts for mounts for two 35” or 37” spare tires, a mounted floor jack and options for one 5 gallon jug with a Pelican case or 3 mounts for 5 gallon water or fuel jugs.
Both kits are available for ordering now! Poke around on the website, figure out which kit you'd like, what shocks you want to run, and call me at 855-WOG-OFRD and I'll put together a deal for you on a kit that'll crush any factory replacement 3.0 Raptor!
