Wiring my 4 lights to my Ford racing lightbar - words of wisdom?
Darkalley
Guys I am going to set up my 4 KC lights and my Ford Racing lightbar this weekend and was wondering if you have any words of wisdom? I've watch the videos and read the posts but anything you figured out during your install that you said "crap if someone told me that I would have been done an hour ago!!!"
Thanks and will post pics!
Raptor911
Ashburn, VA
Curse the gods that made you as you will swear like a sailor when you try to make the connections under the dash.
Rookie
Fort Wayne, IN
Go ahead and cut the tape and pull the harness from the clips under the dash. It'll save you a lot of time and headache trying to solder the connections.
Darkalley
Thanks guys. I couldn't find any reviews of these lights but I liked they were old school round w new school LED tech.
Darkalley
They are 6 inch lights- I put the $20 up to show u the depth. I liked that they also fill in a little of the gap between the light and grill vs the skinny yet large 8 inch KC's
Darkalley
sarcasm aside, whats the amperage of these lights?
Hmmm here is the spec sheet. I can run two lights to one switch right? I'm just connecting two to one of the pass thru wires correct?
http://www.kchilites.com/downloads/dl/file/id/210/643_644_data.pdf
20W per light - 2 x CREE XML2-T6 10W LEDs
• Available in Spot Beam (focused bright light) and Spread Beam (wider bright light)
• Raw Lumens: Spot Beam - 2,104 per light, Spread Beam - 2,104 per light
• Lux @ 10 Meters: Spot Beam - 2,150 LX per light, Spread Beam - 1,310 LX per light
• Candela: Spot Beam - 210,400 CD per light, Spread Beam - 131,000 CD per light
• LED Color Temperature: 5000K
• 9V to 32V, EMI DO 160E Compliant
• 6” Round LED light with precision machined reflector optics
• Patented Gravity Reflective Diode (GRD) technology yields more controlled and farther reaching light beams
• High Grade Aluminum housing with Hard Coated Polycarbonate Lens
• IP 68 Rated, Fully self contained and sealed LED light housing
• Rugged and durable, 6" round black composite Polymax Housing
• Adjustable mounting bracket for easy and accurate aiming
• Protective and stylish ABS Stone Guards included
• Deluxe Plug-N-Play Wiring Harness
• Easy to Install Instructions
95,535
59,160
tonypaul07
