Whipple recently released their own 20 psi Boost/Vacuum mechanical 2 1/16" gauge for customers to monitor boost pressure from their Supercharger. This gauge will give you good indication of engine vacuum at idle and running conditions as well as Boost when you a little heavy on the pedal!! This gauge mounts in the AC vent with a Roush mounting pod.
The Gauge is $85.00 Sold separate. http://www.teamjdm.com/whipple-mechanical-boost-gauge-2-1-16/
Mounting Pods are $32.99 Sold separate.
Order together and we will offer these two for $109.95 + S&H.
*order time at this moment is two weeks. We are working on a stocking order to have them readily available to our customers.
Now for our special offer!! If you are ordering a Whipple Supercharger between now and the end of this year 2015. We will include a FREE Gauge and FREE mounting pod with your order!
Get real time vacuum and boost readings from your Whipple Charged engine with our mechanical -20 to 20psi boost gauge. Featuring a black face, white text and a LED light for easy to read at all times. Each gauge comes with simple instruction manual, 1/8" hose and a 1/8" tee fitting. In some cases, you may require a 1/8" NPT to 1/8" barb for tapping into intake manifold. - See more at: Whipple mechanical boost gauge
