Which to choose? A Replacement/Upgrade guide to Fog Lights for your Gen 3 Raptor…
Bullet Bob
Mid-Atlantic
I have to chime in here and say that I too have bought a set of Radiance Scene lights from John for my 2019 Raptor. They are great lights and look good too. John was right there when I texted him during the install to answer my questions. I live in deer and bear country and can attest that the added light has more than likely kept my Raptor out of the body shop, and more than paid for themselves in missed insurance deductible costs.
High quality product, great service, great results and importantly, great guy to deal with.
When my 2022 gets here, I'll be calling you again John.
Specialtyperformanceparts
Thanks again! I can't thank you enough!
John
catinthehat85
Socal
Incredible write up!!
Question: I’m interested in the triple fog brackets so I can add DD SS3 pros. Is it possible to only add two SS3s per side instead of 3? 3 just looks too crowded for me, I would be perfectly happy with two per side.
Adrenlin
NC
Just wanted to give a shout out in regards to the SPV Parts 2021+ Ford Raptor OEM Fog Light Upgrade Kit with Brackets & Rigid SR-M Direct Replacement Lights I recently purchased and installed.
What I was looking for were replacements that match the stock look, but with higher output. That is exactly what I received. Top notch kit, and everything was easily installed. If you didn't know better, you'd think this was ordered directly from the factory.
One small tip that may save some people a little time, at least with the Rigid SR-M.... I found out that you don't have to remove the housing from the truck's bumper. Once you back out the four bolts that secure the back cover and subsequently remove the cover, you can access the screws that hold the factory light in place. This allows you to avoid touching the T30 Torx bolts that attach the light housings to the bumper. The inner Torx bolt doesn't have a lot of clearance around it, so not having to touch those bolts made things much easier.
Thanks for the great comment and support!
John
You can put 2 or 3 if you prefer. Or you could even put a 6 or 10" light bar potentially, or multiple smaller lights on them within the spacing.
John
WTX
The Permian Basin
Great info. Great company to buy from. John spent 42 mins on the phone with me a couple weeks ago as I was on the fence about fog lights. To replace or upgrade factory. He went through the pros and cons of both, then went through the same process with rear/reverse lights. Products were shipped quickly and instructions and hardware were perfect. Super easy install. I’ll order again from John. Great service
We are always happy to help!
It can definitely be difficult to make decisions with some many options out there. Having a better understanding so you can make the right decision that fits you, is what we strive to offer.
John
