Wheels size
So-Cal-Al-52
I Love Fossil Fuel
San Diego
As long as they are a 6x135 bolt pattern and hub bore 87mm they will fit. That does not mean tires won't rub, but if you stick with 35"s you should be okay. 00 Offset is okay as long as the tire size isn't too big. The only issue with 9 wide and 00 offset will be the tires hitting your fenders if you fully compress the suspension. Another member tried these with 37's and his truck rubs.
oscargarcia1158
Las Vegas
thank you for the information. i will placed the order today on these wheels then.
