HoldenTX
What is the combined weight of the stock wheel + tire? (Not BL to make it easy)
From my research the stock rim is 31.5# and BFG tire is 65#
BFG does not publish the weight of the OEM C rated 315 (at least that I have seen). The E rated version is 65 pounds. The stock C rated tire should be considerably lighter.
I would guess the stock non beadlock combo weighs 87 pounds (31+56).
The beadlocks weigh in around 36-37 (not sure about the newest version, they look a little lighter).
64.4 lbs for the C rated tire according to BFG's website.
WOW! 95.5 lbs. I just dropped the spare tire to pull the tailpipes to powder coat the tips. Lifting the spare with one hand while attempting to get the mount perch pushed up through the center of the wheel is not something I would ever want to do on the side of the road! I also took this opportunity to balance the spare as well.
-Satch
Theres an easier way than lifting it to push the carrier through the center. Next time keep lowering the line and remove from the top.
