Cerberos
Wheel offset vs. backspace
Last evening I had a close friend, and avid auto enthusiast, ask a rather insightful question with respect to a post on another forum regarding wheel specifications, i.e. backspacing vs. offset. He couldn't figure out why recommended offset would change if wheel width changed.
After a 30 minute conversation and a bunch of scribbled pictures on dinner napkins, it finally made sense to him. In short, recommended backspacing doesn't really change but offset does.
Let's take a look at how this relates to our Raptors. As you go up in wheel width, say from our factory 8.5" to 9", the required offset drops. In this example, you would only need +28mm of offset in a 9" rim to maintain the same backspacing as the stock rim.
Many of us would like just a bit more clearance at the strut, so reducing the offset in the 9" example to +25mm give you 3mm more clearance and still only pushes the outside face of the wheel out 15mm.
Here is a link the wheel offset calculator
