What size Torque for access panel on skid plate?
raptor50trex
i was lazy when i changed my oil because none of my torx fit and the bolts were pretty rusted so i just reached down over the radiator with a filter tool ! getting it back on was a pain...
AngryBird
Near Santa Fe, NM
Anyone know what the P/N is for the skid plate oil filter access panel bolts? They are T40 I think. I'm missing one and the ford dealer can't find it. I really don't want to use a regular M8x1.25 bolt from the hardware store.
Thanks,
AB
MTF
Celebration, Florida
The Raptor is high enough and if you turn the wheels all the way to the left you can access everything from the front drivers side. Oil filter, drip pan is right there and if you place a small aluminum pan on top of the drip pan there's no need for cleanup.
Why would you waste the time to remove stuff?
Well I actually remove the oil filter from the top i just lay a small blanket over the radiator and use my little step ladder for washing the truck.
Loosening bolts all the time IMO is not a good idea.
MTF
It's not that the dealer can't find you one, it's because they don't want to open up a bag for one bolt. Dealers would have to buy like a 20 count bag for stupid money and then it would sit on their shelve as lost inventory.
I went through this my self, I wound up buying a bolt from an online Canadian bolt manufacture. If I find my receipt I post up the website.
---------- Post added at 08:51 AM ---------- Previous post was at 08:45 AM ----------
Have you tried Ford Racing Parts?
---------- Post added at 09:03 AM ---------- Previous post was at 08:51 AM ----------
2010-2014 F150 SVT RAPTOR ENHANCED FRONT SKID PLATE | Part Details for M-5018-F15R | Ford Racing Performance Parts
AngryBird
Near Santa Fe, NM
Okay. I did look on fordparts but not ford racing parts. Thinking about just using a stainless low profile socket head screw from mcmaster. I think it will be recessed enough not to get too messed up. I just hate hex key screws because they tend to strip. What do you guys think? I could also go with the higher strength carbon steel kind but I'm a little worried about corrosion with the black finish.
McMaster-Carr
